Driving mosfet with higer than abs.max current for very short time
demir-ali
Joined Jul 13, 2024
324
Hi , my inverter pulls around 2A peak current for a very short period of time but it is given in datasheet the Id,maxpeak = 500mA
I know in higher frequencies it will fail but would it work or should I go for changes in desing ?
ronsimpson
Joined Oct 7, 2019
4,814
This is a common problem in CMOS. You have the RDSon of both FETs in series across the power supply.
What is the power supply voltage?
You need to have fast rise and fall times of the input signal.
demir-ali
Joined Jul 13, 2024
324
The supply range is not constant like 1.8 3.3. I do plan to make it working around -+5 to -+10
I also think of this kind of design but this one has considerably low V_OH
