They are available in all sorts of sizes and plenty bright too..I like that. Only question is if they make them bright enough and properly sized for my application. I don't suppose you know of one that's 14 mm to 16 mm long?
Not to mention all LEDs are already in series/parallel already so you only need 1 constant current source vs 24 if you use discrete LEDs.. Component count drastically reduced..
As to frequency.. 60Hz can be picked up by "some" humans.. At around 75Hz no one will see the flicker..
