driving a transistor from an op amp?
I have the output of my op amp TLO82 pin one feeding into the base of my 2N3904 via a 1K resistor
the output from the op amp is fine on the op amp side of the resistor but is extremely tiny on the transistor side, I
assume I need to pull something somewhere?
basically how do I interface an op amp with a transistor?
Neil.
The 2N3904 is a BJT NPN Transistor, so the base-emitter junction is similar to a diode with VR of about 0,75V depending of the point of work alias IBase current. The TL082 output is a NPN-PNP totem pole.
A resistor between the output of TL082 and base of transistor 2n3904 is a must and the value depends by the desired collector current (max 200mA) which is IBase*hFE.
The hFE (DC gain) depends of the collector current and is typically equal to 100 with ICollector = 10mA or 30 with IC of 100mA. For example, you want 100mA collector current and the output of TL028 is 5V, the base resistor value is calculated : (TL_Out-Vbe)/IBase; Es: (5-0,85)/0,0033 = 1K2 ohm.
In other words, is normal that the measured VBE is about equal to the VR and in this example 0,85Vdc
