Im trying to drive a 3V stepper motor from a discrete dual MOSFET H-Bridge(P Channel - Highside) (N-Channel - Lowside). I used PMV130ENEA and PMV250EPEA logic level mosfets.
One side of the dual h-bridge looks like the one on bristolwatch.com shown below:
The issue I have is that when the battery voltage goes below 2.5V the motor is not able to close the valve. I believe this is cause there is not enough current for the motor to push the valve closed at a voltage of 2.5V. I want to know how i can push the valve closed at the low voltage?? Will increasing the voltage using a step-up converter allow more current to be drawn from the battery? Any help is appreciated.
