driving 2 leds with weak AC signal
MarFene
Joined Feb 27, 2014
39
I have built a low frequency oscillator using lm324.
the setup is being powered by a dual supply of +5v and -5v , having a ground.
i would like to drive 2 leds , one for the positive part of the cycle and one for the negative part of the cycle without loading the signal. i know i could just connect the output signal to two inverted LEDS in parallel connected to ground but i do not want to load the signal.
can any one of you guys tell me how i can use generic transistors to do such a thing ?
2n2222 ,3906 , 3906
the positive signal led was not so hard to do using 3904, its the negative part that's making me crazy.
dl324
Joined Mar 30, 2015
18,381
Is the opamp output a square wave? If not, do you want the negative indicator to turn on before the output is -0.7V?
MarFene
Joined Feb 27, 2014
39
No the output of the opamp is almost a sinewave with some minor bumps on the decay.
if really there is no other option ill take the solution tih the led not turning off before the 0.7v then.....
dl324
Joined Mar 30, 2015
18,381
Try this
If you want the negative indicator to turn on closer to ground, make a 0.7V reference and use that instead of ground for the emitter connection.
MarFene
Joined Feb 27, 2014
39
yes sir , did the trick , i dont think i will actually do anything about the 0.7v even though it is noticable.
Thanks alot
:) marlon
ian field
Joined Oct 27, 2012
6,536
2n2222 ,3906 , 3906
If both LEDs are red - you can get ultra-efficient LEDs that give a useable indication with only 2mA, the LM324 should be able to handle that with nothing more than a couple of current limiting resistors.
There are some pretty good blue and/or white LEDs nowadays, but with a Vf of about 3.4V - the supplies you mentioned probably don't have enough headroom.
MarFene
Joined Feb 27, 2014
39
ok on a separate note , is it possible i make another 2 leds , one for when the voltage is increasing and one for when the voltage is decreasing?
MarFene
Joined Feb 27, 2014
39
yes ian , the leds are red but i preferred having a very tiny current to drive a transistor rather than connecting the led directly
dl324
Joined Mar 30, 2015
18,381
It will take more than just 2 LEDs. What is the frequency range of your oscillator and how much additional circuitry is acceptable?
ian field
Joined Oct 27, 2012
6,536
If you have split rails, you can capacitor couple an inverse parallel pair of LEDs between the output and the 1/2 Vcc divider, there will only be LED current while the output voltage is changing.
If all you have is +5V Vcc, you may find it necessary to hang the capacitor/LEDs between a full-bridge output setup.
dl324
Joined Mar 30, 2015
18,381
While I was thinking about how to detect pos/neg slope with a couple of comparators, I saw that this circuit would indicate pos/neg signal. It's a little more complex than your current circuit, but this one has no dead zone.
The LM393 operates from the same supplies as your LM324. You can omit R1-R3 if you don't care about the effect of input bias current.
If you tell me what your oscillator frequency range is and how accurate you want slope detection to be, I can offer suggestions.
dl324
Joined Mar 30, 2015
18,381
Guess I can answer this on my own. Since it's a visual indicator, won't be of much use above 10-20 Hz. In that case, you can use a derivative of the positive/negative indicator in post #13. Put a cap after R2 and connect R2 to the input signal; I'd also make R1-3 smaller.
