down counter using 74193 ic
Judy Ann
Joined Oct 1, 2016
10
guys i need help! please give me an idea or schematic diagram of circ, about down counter using 74193 ic ..
Judy Ann
Joined Oct 1, 2016
10
Is this homework? And there were a couple of my questions you did not answer.
Have you read the datasheet?
this is an activity, yes i have read the data sheet.. i have tried my idea but the count is 9-7-5-3-1, then back to 9..
circuit must have a continuity sir, it will not run once...
djsfantasi
Joined Apr 11, 2010
9,237
And how does it start? Just by powering on?
Is the count from 9 to 0 or is it 9-7-5-3-1? Details are important?
Assuming it's the latter sequence, is there something unique about it? Can you describe it to us? How would you represent it in binary?
Judy Ann
Joined Oct 1, 2016
10
by putting the source on.. the count is from 9-7-5-3-1.. there is nothing unique .. when i turn on the source the clock pulse start then the 7segment just display 9-7-5-3-1 number again and again... 1001 - 0111 - 0101 - 0011 - 0001..
djsfantasi
Joined Apr 11, 2010
9,237
Alec_T asked a good question!
And may I add, there IS something unique about that sequence. Look at it again, either in decimal or binary...
bertus
Joined Apr 5, 2008
23,010
Have a good look at the binairy values of the A,B,C and D outputs.
How do they relate to the wanted sequence?
Also what values do you need at the input of the counter to start at 9?
Judy Ann
Joined Oct 1, 2016
10
need 1001 value to start at 9.
22,113
there is nothing unique , the circuit just display 9-7-5-3-1 values
I'm going to be a spoil sport and let you off the hook. In the given sequence the least significant digit is always a 1. So tie that input to the display high. What do the remaining digits do? That's right they go {100, 011, 010, 001, 000}. Those values concatenated with a constant, always 1, least significant digit, make up the desired sequence. Preset the counter to 4, aka 100, let it count down to 0, and reset the counter to 4 on the next clock after the counter reaches 0. Recognizing patterns is half the secret to clever logic and state machine design. It has always worked for me.
Alec_t
Joined Sep 17, 2013
15,158
I'm still puzzled. Do you want to count 9-8-7-6-5-4-3-2-1-0-9-8-7-6-........; or should it be 9-7-5-3-1-0-9-7-5-....... ?
