Double hacking for a audio/visual beacon...
Externet
Joined Nov 29, 2005
2,631
While building a circuit that would flash and beep, it hit me that I could modify a disposable camera to make it.
The periodic flashing could be achieved by replacing the manual 'take picture' switch with a neon bulb, that should trigger the flash repeatedly at a certain cadence.
And previously in the circuit, the AC inverter output should nicely drive a piezo disc loudly, if I bring the oscillation frequency to 2 - 4 KHz
While I look behind the spider webs for my canibalized camera boards; your suggestions are welcome.
AlbertHall
Joined Jun 4, 2014
12,625
Unless 2 - 4kHz is a long way from its intended frequency in which case the transformer isn't going to work too well. Do you know its original frequency?
Externet
Joined Nov 29, 2005
2,631
Thanks, Albert. Measured a few types and found 25KHz, 40KHz, 57 KHz as oscillation frequencies. Would have to bring them to a tenth of that... if I can.
