Dot convention - Determine dots
Ian0
Joined Aug 7, 2020
13,315
oh, how to get the true understanding of these case?
It's like those shape puzzles, where you have to rotate the shape in your mind and determine if two are the same.
So, in your mind, slide the winding around the core, until it is on top of the other winding.
Now do they match? (The number of turns doesn't matter, just look whether the turns go in the same direction)
If so, put the dots at the same end. If not, put the dots at opposite ends.
linhvn
Joined Nov 6, 2024
297
Before I applied Faraday law and Lenz law, suppose current enters 1st terminal, why apply these laws make it wrong?
Ian0
Joined Aug 7, 2020
13,315
Faraday's law V∝dΦ/dt
It's about voltage, not current.
If current enters it must be because there is a voltage across the coil. Flux increase at a constant rate.
An identical coil experiences the same rate of change of flux, and produces a voltage, which must be identical to the voltage in the first coil. If it is a transformer, then that terminal can supply current to a load, so current exits from it.
Far easier to think in terms of the voltages.
If you think in terms of current going in and out, when you try to design a flyback converter you will definitely get in a muddle.
linhvn
Joined Nov 6, 2024
297
Hard to understand what you say, I am still waiting for a shortly clearer explanation.
Jony130
Joined Feb 17, 2009
5,601
In this case, try to use the right-hand rule. And check the flux direction in each winding. And put a dot when the flux is added to each other.
Ian0
Joined Aug 7, 2020
13,315
how about this, just Faraday and Lenz law
It doesn't help a lot, as a transformer is an AC component, and the flux is in quadrature to the voltage, so half the time the flux is going from + to - and half the time it is going from - to +.
Think about it:
if Φ = ∫V1 dt and V2= dΦ/dt then V1=V2 and it doesn't matter what the flux is doing.
linhvn
Joined Nov 6, 2024
297
Think about it:
Why do you think this does not help, this is basic law, no need equations
WBahn
Joined Mar 31, 2012
33,342
I haven't read every response, but it seems like you are (once again) insisting on making this so much harder than it is.
For one of the windings, pick a terminal and put a dot on it.
Now assume that there is a current entering that terminal.
Using the right-hand rule, determine the direction of the magnetic flux in that coil.
Follow that flux through to the other coil.
Using the right hand rule, determine which terminal current has to enter to produce a magnetic flux in that same direction.
Put a dot on that terminal.
Done.
