Dot convention - Determine dots
linhvn
Joined Nov 6, 2024
297
In the third picture, Do I mark the dots correctly? If the current enter the 1 terminal the positive terminal is 4 terminal.
Ian0
Joined Aug 7, 2020
13,288
The N3-N4 winding looks quite loose, move it around the core until it fits over N1-N2. Then does it look right?
BobTPH
Joined Jun 5, 2013
11,661
How do you expect us to explain why your answer is wrong if you cannot (or will not) explain how you got it? For all we know, you think the dots go on the rightmost terminal of each winding.
And, apparently, you did not read the question since it asked you to show the two correct positions of the two dots and you showed only one. Where is the second answer?
linhvn
Joined Nov 6, 2024
297
From what I learn, dots show polarity of windings, If current enters one dotted terminal , then the dotted terminal of the other winding will be positive or we can say current goes out the dotted terminal of the other winding.
linhvn
Joined Nov 6, 2024
297
one is enough, step by step, if current enters all 1st terminal.s
Ian0
Joined Aug 7, 2020
13,288
Pyrex
Joined Feb 16, 2022
556
This E1 is the induced emf, as per definition an induced emf has opposite polarity with current causes it, why in this picture, E1 has the same polarities with V1?
Everything is OK with the picture. E1 and V1 are of same magnitude ( roughly the same) as Resistance R1 is relatively small and Leakage inductance Xj is small , too.
There's a simple test to check the polarity of the transformer windings. Connect a centre zero moving coil meter to the secondary winding, positive terminal to the dot marked transformer terminal. Take a battery of 3-6 Volt and connect it to the primary winding, positive terminal to the dot marked terminal. Watch which way the arrow deflects, it should deflect to the right. If it not, the winding marking is wrong
linhvn
Joined Nov 6, 2024
297
:)) Do I mark the red dots correctly in this problem, just suppose that current enters all 1st terminal?
Ian0
Joined Aug 7, 2020
13,288
You are wrong on all three cases.
At a guess, from the fact you have drawn arrows, you are still thinking of it in terms of current flow.
