Flyback dot convention in transformer
mishra87
Joined Jan 17, 2016
1,063
Hey Guys,
My concept is shaking with transformer dot convection. i want to show you the case study of two circuit.
As per my understanding SW is on voltage develop at dot end is positive and when SW is off voltage polarity reversed.
case 1: SW=ON, Voltage at dot end of L1 is + so secondary side voltage at dot end is + and D2 side is negative hence D2 is reverse bias.
SW=OFF, Voltage at dot end of L1 is - so voltage secondary side at dot end is - hence D2 is Forward bias.
Case 2: In this circuit i did the same but this does not work.
When SW is ON diode gets forward bias which is against the theory of flyback and vice versa when SW is off.
I know both are correct design but trying to figure out with voltage across transformer winding approach.
Hope somebody will answer me.
Thanks in advance !
Regards,M
dendad
Joined Feb 20, 2016
4,642
The dot indicates the start of the winding as far as I understand. It is not +ve or -ve.
If you swap both windings, the circuit should work the same. When the FET is on, in the second circuit, the dot is not +ve but -ve as it is connected to the gnd just the same as the top circuit.
ronsimpson
Joined Oct 7, 2019
4,888
Part of what is confusing about a flyback transformer is that it functions very differently than a power line transformer.
With a flyback transformer, power is put on the transformer when the transistor is on. The power is stored and comes back out when the transistor is off.
Ian0
Joined Aug 7, 2020
13,315
Hey Guys,
Thanks in advance !
Regards,M
A flyback converter does not have a transformer. It has an inductor with two windings.
A transformer does not store energy, but an inductor does.
The dot does not represent positive or negative. It just shows the relative phase of the two windings.
Your first diagram is correct. When the MOSFET is off its drain voltage is higher than the supply voltage, so the dot end of the winding is the more positive.
mishra87
Joined Jan 17, 2016
1,063
Thanks to call for answer.For me still some physics is missing.
If we want negative output voltage from flyback so that is really confusing how to put diode and transformer start winding.
There should be some physics.
dendad
Joined Feb 20, 2016
4,642
Negative ouput?
Try your original circuit and just hook the C1 V+ to gnd and use the C1 V- as the supply feed.
Ian0
Joined Aug 7, 2020
13,315
Yes, but the inductor acts like a transformer in that it takes power from the input winding and transfers it to the output winding.
I would disagree, as no power is output when the input winding in energised, and power is only output when the input winding is effectively disconnected.
In the model of a perfect transformer, there is no mechanism for the storage of energy. The core has infinite permeability
ronsimpson
Joined Oct 7, 2019
4,888
All other transformers have inductance and permeability and resistance and capacitance and a resonant frequency and ......
Does it matter? if you see a transformer as a thing or you see it as two or more coupled inductors.
38,943
Infinite permeability means infinite inductance.
The ideal model of a transformer in LTspice has inductance.
All practical transformers have inductance that can store energy so can be used in a flyback converter circuit.
The name for the magnetics with more than one winding used in a flyback circuit is commonly called a flyback transformer.
Why do you want to make a distinction in name that is not normally used?
Ian0
Joined Aug 7, 2020
13,315
because it is fundamental to understanding the difference between the component used in a flyback converter and the component used in a forward converter circuit, which ostensibly look the same; and the different way that the two circuits operate.
In a transformer the output voltage is proportional to the input voltage. In a flyback converter, it isn't.
There are plenty of instances in electronics of things being called by a name which is not perfectly accurate.
ronsimpson
Joined Oct 7, 2019
4,888
Just to be a 'donkey' about it: In a flyback converter, the voltage across the primary and secondary are proportional to each other.
Example. During the output time, the secondary voltage X turn ratio = primary voltage.
During the input time, the primary voltage X turn ratio = secondary voltage.
I understand that the entire power supply, input to output, is not directly related to turns ration.
Ian0
Joined Aug 7, 2020
13,315
Agreed. Whilst the switch is on, the voltage on the secondary is proportional to minus the primary voltage, and when the switch if off the primary voltage is the supply voltage plus a voltage proportional to the output voltage, but those are only significant is choosing the voltage rating of the rectifier and snubber. In terms of the entire converter, they don't make the output voltage proportional to the input voltage.
38,943
Not the converter output, but the output voltage of the flyback transformer is indeed proportional to the turns-ratio times the flyback voltage at the input.
