Hypatia's Protege
- Joined Mar 1, 2015
- 3,228
FWIW they're rather handy!The ones I messed around with had a small PCB size transformer in them, Around a 0.650" cube.
Best regards
HP
Yea but if you use it to charge a big capacitor it could be a long wait if the Cap isn't formed! I don't know what value series resistor the pflash modules use but it takes a good 30 seconds to charge a 100uF Cap to 300V So that's 150mJ per secondI have found said devices to be an ultra-compact solution to certain applications 'traditionally' featuring CCFL transformers where only 'flea power' output is required (e.g. PMTs, GM tubes, 'capacitor chargers', neon indicator lamps, etc...)
No kidding?!Yea but if you use it to charge a big capacitor it could be a long wait if the Cap isn't formed! I don't know what value series resistor the pflash modules use but it takes a good 30 seconds to charge a 100uF Cap to 300V So that's 150mJ per secondAnd I forgot to mention that electrolytics are leaky!
