DIY power transformer help
quitenoob
Joined Mar 27, 2022
262
I think @BobTPH and I were correct regarding it should not matter if one winds up or down.
One thing to note here though I still believe it is important to keep winding in the same orientation. Although I did not confirm this I am not going to even bother. That seems so obvious to me by now. No nagging thoughts about that one.
Here you can see 27 consecutive winds around a 100mm diam tube. the custom field meter reads. .3
Here You see the results when I wind back half way through.
quitenoob
Joined Mar 27, 2022
262
This also answers the question if we can stack the windings of coils. YES we can
quitenoob
Joined Mar 27, 2022
262
Well here comes the fine print. Apparently stacking is possible but it wont give us double the output.
So earlier suggestions regarding not to stack seem very valid.
I for one will no longer stack
quitenoob
Joined Mar 27, 2022
262
Sorry guys. Changing my mind again about stacking or not.
Please help me reach a conclusion that sticks a bit longer :)
With 27 non stacked winds.
To reach a custom field strength of .3 we need to pass 331 mvolts through the coil which it self draws 4.5 amps.
With around 13x2 stacked winds
To reach a custom field strength of .3 we can pass a bit less mvolts (317) and the coil is drawing a bit less amps (4.23)
That makes me think having a fat coil helps is delaying saturation of the coil. Certainly have a good core helps better with that but I am no longer so sure that stacking is a bad thing.
However I will try and prevent stacking non the less. Because it also helps make the transformer look a bit better. I know I've said I can care less about how it looks. I am starting to change my mind about that.
quitenoob
Joined Mar 27, 2022
262
A real4.1kVA tra nsformer I measured a while ago had an off-load primary current at 240V of 0.63A.
How does yours compare?
@Ian0 , come one man. what made you imply my transformer is not real?
What if I told you that even vigortronic UK are telling me that they can't get it better than 60%. And what if I tell you that I will die trying to get anywhere near that?
And what If none of the above is true. (which it is) then still there is nothing that warrants the distinction between a real and an unreal transformer unless you tell us all how that distinction is made for all to determine valid or not.
ADDITION to: 1kVA tra nsformer I measured a while ago had an off-load primary current at 240V of 0.63A.
I have absolutly no idea what that all means.
what is KVa, off-load, and what has one.
I am a slow learner once again.
One of us suggested to go the inductance measurement route earlier.
And then I went and gave it a go and got intimidates reallllly quickly
ADDITION2:
So I kindly request all readers to react to my requests for help. Suggests ways on how to find information to learn more.
Suggest new ways of field testing, but then explain how to do it for dummies like I am.
And many other ways I have not thought of yet.
But I do not welcome just random blowback unless it is backed up
Ian0
Joined Aug 7, 2020
13,288
I don't see ones like it offered for sale!
That's typical for a very small transformer. Larger transformers are more efficient, >95% at 4kVA
kVA is the same as kW for a resistive load.
off-load = nothing connected to the secondary
quitenoob
Joined Mar 27, 2022
262
May I please ask for some assistance?
For the life of me I can't find a schematic on how to hook up the 2 diode components that were suggested earlier into a single phase full bridge rectifier.
Is there anyone that can draw something crude? I need only the slightest of lines as long as it is clear what is connected to what.
quitenoob
Joined Mar 27, 2022
262
I am not sure anymore who suggested compacting the powder.
I did try today.
I can compress it using a vice. It is compressible yet it will never become a solid structure with the force my vice can apply.
Also there is no noticeable field enhancement in compressed state.
I am not sure if it is worth trying to get bigger tools to compress more extreme
strantor
Joined Oct 3, 2010
6,875
can you post a (low res) picture of the diode components in question?
quitenoob
Joined Mar 27, 2022
262
I have not yet, at first glance though I am not sure it is electrically insulated thus of no use. Also it is rather thick. I am going with .4mm wire for the coils.
This was not to say I am not open to suggestions and not willing to change my mind. I constantly change my mind.
It's a process.
EDIT: ugg. sorry core is not the same as coil. my apologies. I will have to have some more time to get this one through my slow moving head
Ian0
Joined Aug 7, 2020
13,288
It's a process.
True, it could perhaps do with a bit of insulation to stop eddy currents. You could spray it with varnish.
quitenoob
Joined Mar 27, 2022
262
Although I am happy for suggestions. I am not going to entertain this one at the moment. I am waiting to go all out on the powder route.
If I fail to improve on the 39% efficiency I have now as my baseline I will report it. At which time please remind me again about this avenue then if one thinks it could help boost efficiency.
Hymie
Joined Mar 30, 2018
1,347
With regards the question of full wave rectification using only 2 diodes, this requires a centre tapped transformer, where the centre tap is the zero volt line and the plus volts is fed from each of the windings via a single diode. With a single secondary winding, a bridge rectifier consisting of 4 diodes is needed to achieve full wave rectification.
strantor
Joined Oct 3, 2010
6,875
The VS-UFB280FA20 diode modules are 2 diodes in 1 package so you have 4 and can therefore make a full wave bridge rectifier.
Like this:
I drew that a stupid way. I don't know why, I was trying to make it as close to the normal symbol for bridge rectifier. And now that I realized there is a better way to draw it I'm not sure why the normal symbol is drawn the way that it is. I think I will draw bridge rectifiers this way from now on. Simpler and makes more sense to me.
quitenoob
Joined Mar 27, 2022
262
Hahaha it happens to the best of us. Have no shame about it ;)
I will stare at this schematic as well for a while. I think I have your first one now totally second nature in the meantime.
It will take me some more staring to also incorporate this one.
They both work do they? It's only the schematic-al layout that is different? I am guessing it should be otherwise that would mean there are more ways to connect 4 diodes in a single phase full bridge rectifier setup than one.
Anyway I already started experimenting with how to get a 35mm2 wire on these tiny terminals.
Should I fail I will get 1000 amp diodes if they exsist so that the terminals will be elephant size ;)
