DIY CRT oscilloscope only displays in tiny part of the screen.
Tyler Simmons
Joined Mar 30, 2019
22
I have wired an old crt tv to display like an oscilloscope. It is working, but the problem is it is only displaying a on a very thin portion on the center of the screen making it hard to read. Is there a solution to this or should I try a different tv?
Also, is this project in any way dangerous to my eyes or skin due to some kind of radiation?
34,790
Give us some more info and maybe we can help you.
Photos of your DIY circuit, schematics, and a photo of the CRT screen would be useful.
(I did convert a TV monitor to be used as an X-Y hi-fi stereo display.)
Ya’akov
Joined Jan 27, 2019
10,234
The real danger of a CRT is the high voltage power supply. You have to be very careful around the flyback transformer, the anode cap:
and anything it is connected to. The dirtiest parts of the chassis are the most dangerous, the get that way because they attract the dust.
Tyler Simmons
Joined Mar 30, 2019
22
The tv model number is srt2319, sylvania. my connections are horizonatal coil----->vertical coil terminal on pcb. vertical coil-------->frequency generator. I adjusted the brightness of the line with the screw on the transformer.20190414_180301.jpg 20190414_180342.jpg 20190414_180324.jpg second picture you can see the white connector where the horizontal coil is connected. The last picture shows the gm328 I am using for the frequency signal.
34,790
How much do you know about TV scan and circuitry?
Horizontal and vertical deflection are accomplished using AC coils for magnetic deflection.
The horizontal deflection is optimized to work at 15.7kHz.
The vertical deflection is optimized to work at 60Hz.
Tyler Simmons
Joined Mar 30, 2019
22
hrmmmm. I'm not sure what you mean MrChips. I don't know really anything about TV scan and circuitry. Just looking at diy guides and videos about the oscilloscope. But none of them seem to have any info about the wave only showing up in the middle.
BR-549
Joined Sep 22, 2013
4,931
The trajectory of the electron beam is controlled differently in scopes, than they are in tvs.
One controls with the magnetic and one controls with the electric. The magnetic(tv) moves the beam in a constant manner. No matter the input. It paints a constant full picture or raster of straight lines.
The electric(scope) only follows the input. It paints only one squiggle line. So...control of vertical and horizontal will be quite different.
Buy a scope.
Tyler Simmons
Joined Mar 30, 2019
22
Buy a scope.
Thank you for the suggestion but that is not possible right now.
Well, I would say the the drive for the two coils is insufficient.
Bob
Some of the videos just detach one of the coils and add an audio signal and this works. I'm not sure what I can do to increase the drive. Ill just try another tv for now. I've tried about everything I can think of and made the tv do some weird squealing.
BR-549
Joined Sep 22, 2013
4,931
My advice is to NOT play with anything over 50 volts, until you study and understand electricity.
It can be most unforgiving to you and your loved ones.
34,790
Let me save you a lot of grief. The problem is not with the TV you now have. Trying another TV will produce the same results.
The deflection coils on the TV require a lot of power to deflect the electron beam.
If you are looking for a simple oscilloscope there are some low cost options starting at $0.
LesJones
Joined Jan 8, 2017
4,511
I think that disconnecting the horizontal scan coil from the line output transformer will prevent the EHT supply working correctly. I think you would have to have a spare scan coil connected to the line output transformer but not on the tube neck for the EHT supply to work correctly. I agree with the advice not to play round with this project until you have a much better understanding.
Les.
Tyler Simmons
Joined Mar 30, 2019
22
Les.
You mean I need a identical coil to trick the board to think it is still connected? Does this matter how close to identical it is? I have some ballast, could these work too if I have one close enough to the same resistance?
DickCappels
Joined Aug 21, 2008
10,661
Is the "ground" of your TV set's chassis connected to AC neutral? Many TV sets were made that way. If the TV set circuitry is not isolated from the AC line with a transformer you, your circuits under test, and your scope are all in grave danger. The common solution isi to put an isolation transformer between your TV set and the power line.
With any luck, an expert on that chassis will be along to comment.
Tyler Simmons
Joined Mar 30, 2019
22
It is. Since I do not have an isolation transformer, I would guess it is equally safe to use 2 transformers to step down, then back up?
I have already taken this tv apart so I will have to try this project later. I will read more about it until then.
DickCappels
Joined Aug 21, 2008
10,661
Back to back transformers work sometimes. The main issue is poorer "regilation" on the output. It is probably best to use larger transformers if you have a choice.
That combination should give you nice isolation.
