Divided by a Common Language
atferrari
Joined Jan 6, 2004
5,024
In UK it would be BOY.
On that regard, I've found this which shows up, again and again:
Why a ship is called "she".
A ship is called a she because there is always a great deal of bustle around her; there is usually a gang of men about. She has a waist and stays.
It takes a lot of paint to keep her good-looking.
It is not the initial expense that breaks you, it is the upkeep.
She can be all decked out.
It takes an experienced man to handle her correctly.
Without a man at the helm, she is absolutely uncontrollable.
She shows her topsides, hiders her bottom and, when coming into port, always heads for the buoys.”
18,149
A simple solution. Gracias Wayne.
I have always been intrigued why everybody pronounces the particle "ou" in "Houston" so differently as you do in, for example, "noun", "mould", "bound".
Well for one thing, it is a name, and presumably Sam Houston's name was pronounced the way it is now. If I had never heard of Houston and came across this name in a book, I might read it as house-ton
