Diode ID
spike1947
Joined Feb 4, 2016
537
Hi
I have a couple of Diodes on a Power Board that need replacing , seem to be having a problem getting the exact same: SR2A0 ! .
Can anyone suggest a replacement Diode ?.
Spike
Papabravo
Joined Feb 24, 2006
22,111
Only way to tell is to run down accurate datasheets for both parts. Without that, making the determination will be pure guesswork. Are you OK with pure guesswork? How has it worked for you in the past?
Papabravo
Joined Feb 24, 2006
22,111
Doe R mean Regular and S mean Superfast ?
That seems highly unlikely. If there is some "encoding" in the part number it will likely be detailed in a proper datasheet. That is the only way to be sure. One more thing: in a career spanning half a century I have never heard of diodes being referred to as "Regular" or "Superfast". I'm pretty sure those terms have no precise technical meaning. Did you make them up?
spike1947
Joined Feb 4, 2016
537
Do you even know what to look for, when comparing two diodes for a specific application?
Short answer , no , there is some different info on both of these data sheets ! .
Yes, sorry was getting mixed up with another post regarding ceramic fuses, been a busy week ! .
First thank you for your replies, much appreciated .
The SR2A0 is a Schottky Barrier Rectifier, and the RL207 is a Silicone Rectifier, now has you have found out my knowledge of Diodes is very limited, I am only a common garden Electrician.
Below a "Fast" Diode !!
http://www.farnell.com/datasheets/2861123.pdf
Papabravo
Joined Feb 24, 2006
22,111
The major difference between a Schottky diode and a silicon diode is the forward voltage drop. It depends on the current through the diode, but for a Schottky diode it is between 0.2 an 0.3 volts. For a silicon diode it is between 0.6 and 0.7 Volts.
Another factor to consider is the Reverse Breakdown Voltage. This tells you how much voltage in the reverse bias condition the diode can stand before it fails. Using a diode(s) in a rectifier this specification is critical. You need a higher reverse breakdown in Europe where the mains voltage is 240 VAC.
Fast Recovery and Ultrafast Recovery refer to the Reverse Recovery Time. Using a diode with an inductor it is important to know how long the reverse recovery period will last.
"When switching from the conducting to the blocking state, a diode or rectifier has stored charge that must first be discharged before the diode blocks reverse current. This discharge takes a finite amount of time known as the Reverse Recovery Time, or trr. During this time, diode current may flow in the reverse direction."
