Dim error
camerart
Joined Feb 25, 2013
3,847
Hi C.
The problem is located here, using the Run command until the break command, then Single Step shows the error.
E
On High Interrupt 'go via location 0x0008
Save System
If PIR2.CCP2IF Then
serialCount = serialCount + 1
wordTemp.LB = CCPR2L 'ensure next interrupt is
wordTemp.HB = CCPR2H 'in 208*4=832 instruction cycles
wordTemp = wordTemp + 208 '208 is 2,000,000/9600 = 104uS or the time for 1 bit at 9600 baud
CCPR2H = wordTemp.HB 'it's really important that the high byte gets written first
CCPR2L = wordTemp.LB 'write it back
Break '''''''''''''''''''''''''''''''''''' break point
PORTC.1 = 1 '''''' error msg
LATC.1 = PORTC.1 'ensure latch is same as current CCP output
If ccpDone Then
Hi E,
I get the same result, well done.
Now I've got to figure out what the problem is, or I can try describing it to the composer.
Thanks. C.
