Bordodynov
- Joined May 20, 2015
- 3,428
Both images are false. When you combined the two resistors (Ry + hie4) You have hidden "base" inside united resistor. Where the base you do not care. The importance of the base current.
So why does @Jony130 says that the Base is grounded?Both images are false. When you combined the two resistors (Ry + hie4) You have hidden "base" inside united resistor. Where the base you do not care. The importance of the base current.
Yes, exactlyI'm going through your equations, but the one for the currents at node E, according to the signs that you used, suggests that IB and IE current are flowing out of the node E, and hfe*Ib and I_ro are flowing into node E, right?
No. In my diagram the CCCS current flow from top to the bottom ( into node Ve) only if Ib is flow in the direction I drew on the diagram.If my thought is correct, the Ib current direction you drew in the schematic should be out of node E into the node GND, no? Because the very next equation you say that that same current have the minus sign!
I also use Vx = 1V and this is why Rout= 1/Ix is trueRout=Vx/Ix not Rout=1/Ix !
But the final result is true. When I make these calculations, I instead of unknown value (Vx) using 1V (Ux = 1). This method eliminates of mathematical expressions (equations) one variable.
It is grounded through hie4 and Ry. There's no signal (AC signal, that is) coming from Q3, so the base of Q4 is effectively grounded through hie4 and Ry.So why does @Jony130 says that the Base is grounded?
Of course you hoe3 have in mind ?Notice that Jony130's result is equal to mine to 7 decimal places. The tiny difference is due to the fact that he didn't take hoe into account in his expression for Ry. It makes essentially no difference to ignore hoe in the computation of Ry, but it is crucial to include it in the computation of Ro
Of course.Of course you hoe3 you have in mind ?
I just simply solve for Ve using this nodal equation
Also, which program you are using to write your equations ?
That operation is only for simplification or is it to calculate something else??? I got lost in the meantime!Your equation is correct. Now divide is by RE||(hie+Ry)
Yes, for Ix.Is that for Ix???
