Differential Amplifier circuit
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Yes, for Ix.
Ix = Ve/RE||(hie+Ry) also Vx = 1 therefore Rout = 1/Ix
wow, that will end up in an huge train of equation... I tried to do it using the the usual result for that parallel and probably, your short for the parallel result will probably work better!
PsySc0rpi0n
Joined Mar 4, 2014
1,786
I got this:
\(\displaystyle {\frac{\left [ V_{x}\cdot \left ( hie+R_{y} \right )\cdot r_{o}\cdot R_{E} \right ]\cdot \left ( R_{E}+hie+R_{y} \right )}{\left [ r_{o}\cdot \left ( hfe+1 \right )\cdot r_{o}\cdot R_{E}+\left ( hie+R_{y} \right )\cdot \left ( R_{E} +r_{o}\right ) \right ]\cdot R_{E}\cdot \left ( hie+R_{y} \right )}}\)
Jony130
Joined Feb 17, 2009
5,599
You need to check your math. Or maybe try to solve this one
\(Vx=Ix*Rx + (Ix - (\frac{-Ix*Rx}{hie+Ry})*hfe)*ro \)
Rx = RE||(hie+Ry)
Bordodynov
Joined May 20, 2015
3,431
I see heaps of formulas, in order to obtain more accurate results. But if the precise formulas are substituted inaccurate data, the result is inaccurate. Once again, that "beta" does not equal "BF". "BF" Spice is an option. Just perfect for the transistor are equal. Gain coefficients everything else depends on the parameters:
is=14.34f xti=3 eg=1.11 vaf=74.03 bf=255.9 ne=1.307 ise=14.34f ikf=.2847 xtb=1.5
The gain depends on the operation mode.
I have given the scheme for calculating the coefficients using LTspice: Beta_dc and Beta_ac.
PsySc0rpi0n
Joined Mar 4, 2014
1,786
@Jony130 I'll deal with the equation later! I'm at work and without time now!
Ok, I'll have that in mind... but somehow all the previous calcs have been close to LTSpice. But that's not the most important. The most important is the process of evaluating the symbolic formulas!
Bordodynov
Joined May 20, 2015
3,431
Ro=VAF/ic ==> Ro=VAF/icq4=74.03V/4.203mA=17.61kOhm=17610,
hie=25.8e-3/4.226e-3*(255+1) = 1562.896 !
LTspice ==> Rout_Current=489.44kOm Beta_Acq4=188.7 hie4=25.8e-3/4.226e-3*(188.7+1) =1158.13
Beta_Acq4=178.06799 hie3=25.8e-3/4.226e-3*(178.06799+1) =1093.22
PsySc0rpi0n
Joined Mar 4, 2014
1,786
The reason he said that is because it doesn't give the same result:
Your expression in post #106 gives the correct result.
I'm not getting the same result... Notice that the 'ro' of the denominator is multiplying by the whole denominator! I'm not sure if your result is taking that detail into account!
I'm getting 1.6 MΩ
I just did a small script in Octave to make things easier...
Code:
Re4=200;
hie=3000;
hfe=255;
ro=100e3;
Ry = 192;
Rp = 1/((1/Re4)+(1/(Re4 + hie)))
Ry=192
Ve = (ro*Re4*(hie+Ry))/(ro*((hfe+1)*ro*Re4+(hie+Ry)*(Re4+ro)))
Ix = Ve/Rp
Rx = 1/Ix
Ix1 = (ro*Re4*(hie+Re4)*(hie+Re4+Ry))/(Re4*(hie+Ry)*ro*((hfe+1)*ro*Re4+(hie+Ry)*(Re4+ro)))
I'm getting 1.6 MΩ
Code:
Re4=200
hie=3000
hfe=255
ro=100e3
Ry = 1/((1/Re3)+(1/(Re3+hie)))
Ry=192
Ve = (ro*Re4*(hie+Re4))/(ro*((hfe+1)*ro*Re4+(hie+Ry)*(Re4+ro)))
Ix = Ve/Rp
Rx = 1/Ix
Look closely. I am multiplying the entire denominator by ro.
It appears you made a small mistake line 8 as shown in red:
Ve = (ro*Re4*(hie+Ry))/(ro*((hie+1)*ro*Re4+(hie+Ry)*(Re4+ro)))
You should be getting 1.6 megohms, as I showed in post #107
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Yeah, already corrected it at line 8.
Yes, I'm getting 1.6 MΩ, sharp...
But what is the difference between your post #107 and #109???
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Ah ok... My result is 1.6 MΩ and your is 1.6039689 MΩ. It's yet 4kΩ of difference... Wonder if this is a significant difference! Maybe it's because you used the exact value of Ry which was a bit lower than what I used... Like 191.... Ω against the vale I used of 192 Ω
Bordodynov
Joined May 20, 2015
3,431
Morning
I am sorry.
Beta_Acq3=178.06799 It is this value should be taken for the calculations. If you take the Beta_Acq4, will double, depending on the accounting (Ic=F(beta,VAF,Vce))
I'm sure that's the difference.
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Well, after running the circuit with the current mirror in LTSpice, somehow the Adm is half of what was before... Why is that?
From calcs I got pretty much the same, but LTSpice shows half of the Adm against the version without the current mirror!
9.6 V-1.3 V = 8.3 V
8.3 V / 2 = 4.15 V
Adm = Vo/Vi = 4.15 V / 0.45 V = 9.22
It should be around 18.
Not sure what is happening!
Edited;
Will it be due to the fact that I'm using Voc1 with respect to GND and not with respect to Voc2???
