Differential Amplifier circuit
Jony130
Joined Feb 17, 2009
5,599
Maybe this will help:
First notice that the voltage at Q4 emitter is
Ve = Ix * (Re4||(hie+Ry)) and if substitute Rx = (Re4||(hie+Ry)) we have Ve = Ix*Rx
Next we notice that I_hoe = Ix - (-Ib*hfe) and Ib is (Ix*Rx)/hie we have our KVL equation
Vx = Ix*Rx + [Ix - ((-Ix*Rx)/hie*hfe)]*hoe
And now all you need is to do it solve for Ix and Ro = 1/Ix
PsySc0rpi0n
Joined Mar 4, 2014
1,786
By Rx you mean the output impedance of this right side block, correct?
Also I didn't understood why I_hoe4 = Ix - (- IB*hfe)...
I would have considered that at node C, we have hfe*IB flowing out of the node C into node E and I_hoe flowing out of the same C node into E node, so I would write that Ix = hfe*IB + I_hoe, therefore I_hoe = Ix - hfe*IB.
Also I didn't understood how Ib = (Vx*Ix)/hie.
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Ah ok... Sorry!
I've added some text to my previous post after hitting the "Post Reply" button
Jony130
Joined Feb 17, 2009
5,599
Notice that Ib flow in opposite direction the the Ix. And this is why we must have a minus sign.
http://forum.allaboutcircuits.com/attachments/qrms9oo1-png.96632/
Ah you are right. I completely forgot about Ry
Ib = (Vx*Ix)/(hie + Ry)
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Ok, I got it about the minus signal... I was thinking about hfe*IB current direction...
But about IB, I'm not sure I get it!
Im trying to use units to try to track your thought!
Vx = Volts
Ix = Amps
hie + Ry = Ohms
So we have ( V/Ω )*A and V/Ω = A, so the result of that equation should be A^2... I'm not understanding. I'm sorry!
Jony130
Joined Feb 17, 2009
5,599
Forgive me, I'm sick today and I have a fever.
Look at my original post #16 and you will see that Ib is (Ix*Rx)/hie. So the correct equation for Ib is :
Ib = (Ix*Rx)/(hie + Ry). Now everything looks ok. I hope so.
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Yeah... I'm sorry for your health condition! I hope you get better soon. Festivities are about here and would suck that you have to go through them sick!
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Yes, you are right. THX for kind words
I'm sure you'll get better quick...
About the IB equation I'm still trying to understand it!
I've attached a picture. I'm not understanding the relation you're using to write that I_hoe = Ix - (-hfe*IB)...qrmS9oo3.png
At that Emitter node we have that
hfe*IB + I_hoe + IB = IE
<=> I_hoe = -hfe*IB - IB + IE
<=>I_hoe = IB*( (hfe + 1) -1 - hfe)
<=>I_hoe = IB*0 = 0, which, obviously, is wrong!!!
I'm not following your thought!
Jony130
Joined Feb 17, 2009
5,599
After doing all the math I get this result:
\(Ro = h_{oe4}+R_{E4}+\frac{(h_{fe4}* h_{oe4} - R_{E4}) *R_{E4}}{h_{ie4} + R_{E4} + R_y}\)
Jony130
Joined Feb 17, 2009
5,599
Yes, of course you are right. I do not know why but I always think is term of resistance ro. Additional I turn OFF my thinking process today.
PsySc0rpi0n
Joined Mar 4, 2014
1,786
I treat hie4+Ry as a single resistor connected between base and ground.
Ok, I understand that, but I don't understand why you say that the base terminal is grounded! Can you please try to explain me again?
Which version are you considering between the 2 pics attached?
