Diagnosing short to ground issue
Leefreeman97
Joined Sep 19, 2025
36
Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?IMG_7324.jpegIMG_7325.jpegIMG_7323.jpegIMG_7322.jpeg
twohats
Joined Oct 28, 2015
621
Can we have a picture of the underside of the boards please.
The short is likely to be a semiconductor.
Can you indicate where and how you are measuring the short.
Good luck......
Leefreeman97
Joined Sep 19, 2025
36
I am measuring with black probe on the ground plane and red probe on the three circled components, all three beep both sides of the components.
Irving
Joined Jan 30, 2016
5,195
Welcome to AAC
Without removing parts from the board its very hard to diagnose such a fault with just a multimeter; you're looking for resistance differences to ground of a few milliohms. The usual way to do this is power the board at, typically 2 to 3v from a constant current supply of an amp or so and view it with a thermal camera - the faulty part gives itself away by glowing hotter than other parts. Without a thermal camera the other, less effective, way is some freezer spray. Spray the board until well frosted, then power it up and see what defrosts first. Its a bit more hit n miss but does work...
Hope that helps.
35,316
Finding a short across power rails is one of the most challenging repair situations. As @Irving says, you need some special debugging techniques.
1) HP 546A pulser and HP 547A current tracer which fortunately I happen to have.
2) Thermal imaging camera.
3) Cold mist spray to find hot spots.
4) Cut PCB traces at strategic locations.
Irving
Joined Jan 30, 2016
5,195
On the 12v input, but I wouldn't use a full 12v. Looking at your pictures it seems that U3 is a switching regulator generating the 5v and feeding the LM117 which generates the 3.3v. What are the markings on U3?
Irving
Joined Jan 30, 2016
5,195
So that is probably bad then judging by the measurement
Maybe, though it is extremely rare for a resistor to fail short, 99.999% of the time they fail open circuit. What did you measure it as? 510milliOhm ie 0.51 ohm? I doubt your multimeter can measure 0.51 milliohm, ie 0.00051 ohm
