Determining internal resistance of re-140ra-2270.
Man10
Joined Jul 31, 2018
206
According to a file i downloaded the re-140Ra-2270 motor has a nominal voltage of 1.5 volts and no-load current of 0.21 amps, does that mean the internal resistance of a re-140ra-2270 motor is 7.14 ohms?
dendad
Joined Feb 20, 2016
4,642
Not exactly. The resistance is best measured with an ohm meter while the motor is unpowered and stationary. That will determine its stall current. Is the stall current specified?
The no load current will also be dependent on the generated back EMF as well as the resistance. So the Impedance of the motor is pretty complex, and depends on the speed of rotation along with the resistance, inductance and back EMF. It is beyond my math ability to calculate.
Man10
Joined Jul 31, 2018
206
Stall current is specified. Stall current is 2.1 amps. So internal resistance of re-140ra-2270 is 0.714 ohm?
Man10
Joined Jul 31, 2018
206
So, if the stall current is 2.1 amps, then you would think, internal resistance of motor is 0.714 ohm?
