I am designing guitar amplifier with TDA7294 output stage, but i cant find anywhere how big input signal is needed for this IC. I have designed preamp with gain of 6 so with 100 mV peak-to-peak input signal from guitar i got 600mV output signal (i know guitar signal can be bigger). I want to make 40 Watts amplifier and this chip is for 100 Watts max. How do i limit output power to 40 Watts when my volume is at max? I cant find anywhere correlation between input signal and output power. I am scared that if i put transformator of 40 Watts and i got too much gain in preamp that i will get max power at lets say 1/2 turn of potentiometer, or that gain is too low and i won't get 40 Watts at all.
And second question is should i put fuse of 200mA on main or should it be bigger?
