Design and simulate a circuit that takes as input a sinusoidal signal
adi80
Joined Oct 8, 2020
132
1) If you pull up on the (+) input the output goes up.
2) If you pull up on the (-) input the output goes down.
The input signal has 0.05V offset. It is moved up by 0.05V and we want to remove that. There are many ways to do this but one is to use comment 2) above. Connect a very large value resistor from (-) to+5V.
Think about a voltage divider made of R3 and R1. Top is +5V supply and center point is (-) input of amp.
R3 is new.
What value of R3 will give you 0.05V?
I must go away for 1 hour good luck.
Should we reduce the voltage of the resistor by 0.05v
adi80
Joined Oct 8, 2020
132
R3 is new.
100k?
ericgibbs
Joined Jan 29, 2010
21,623
hi adi,
Sorry No. :)
Vout required = 0.25V
Vsupply = 5V
Bottom resistor R1 = 10k
Find value of Top resistor R3.
With your answer of 20K, you would get 1.666' Volts
Try again.
E
ericgibbs
Joined Jan 29, 2010
21,623
hi,
Using a 100k as post #91 would give 0.454V.
Lets go thru it step by step.
Vout = Vin (R1/(R1+R3))
Transpose the formula for R3= ,,, can you do that.?
E
ericgibbs
Joined Jan 29, 2010
21,623
hi adi,
Yes,;)
but please post your calculations.
E
Now do it for Ron's 0.05V as requested in post #80.... use the same method as for post #93,,, post your answer.
