Design and simulate a circuit that takes as input a sinusoidal signal
adi80
Joined Oct 8, 2020
132
What type of components are you allowed to use to make these circuits?
For example, resistors, capacitors, op amps, etc. ?
This is necessary to know beforehand. You might get this info from previous questions in the coursework.
Also, do you know what a voltage divider is?
Or an amplifier?
E12 series components
Resistors
op amp
adi80
Joined Oct 8, 2020
132
Here is a link to a help you learn about op-amps. Use the non-inverting half of the link.
amp gain calculator
Here is a picture of a non inverting amplifier. The wire going up goes to +5 volts and the one going down goes to -5 volts.
The calculator works like this: Fill in Rin and Rf then hit Calculate.
Do you have anything like this in your book?
Please see what i have design without any help. I am happy to share all the pages on which i worked as well.
dl324
Joined Mar 30, 2015
18,467
Cropped image with some unnecessary whitespace removed:
What does this have to do with the problem you're trying to solve? You drew a non-inverting amplifier with a gain of 3 2. That circuit is available in just about any opamp datasheet.
EDIT: corrected gain.
It would be helpful if you put parameters for V1 on the schematic.
This is the more typical way to draw that circuit. From Signetics:
adi80
Joined Oct 8, 2020
132
What does this have to do with the problem you're trying to solve? You drew a non-inverting amplifier with a gain of 3. That circuit is available in just about any opamp datasheet.
Could you please guide me a little what step i should do next. Do I have to add value to Vi and Vout ?
dl324
Joined Mar 30, 2015
18,467
You've already been given a link to a calculator; or you could do the arithmetic yourself. What gain do you need for each amplifier and what are you going to do about the DC offset of the input signal?
adi80
Joined Oct 8, 2020
132
what will be the correct value of E12 series resistors please?
dl324
Joined Mar 30, 2015
18,467
What gain do you need to amplify 0.2V p-p to 2.2V p-p? If you subtract 1 from that, what does the ratio of the two resistors need to be?
When is this problem due? You've already spent days on a problem that shouldn't take more than a minute or two.
adi80
Joined Oct 8, 2020
132
When is this problem due? You've already spent days on a problem that should shouldn't take more than a minute or two.
Thanks, but i still have not completely get it. Do i need to take resistors each of 1 KOhms?
adi80
Joined Oct 8, 2020
132
Is my Schematic wrong?
