Hi BTPH,I think you are missing something in the assignment. Since it was not specified as an AC amp, and there is no frequency range specified, I think it is supposed to be a DC amp. The dual supply is also a clue.
Bob
hi Mr AIHi,
Wouldnt it be simpler to use an op amp?
Hi,hi Mr AI
kindly elaborate your point of view
Yes, we know that. What is your point?I have to design a voltage amplifier..The first task is to develop a voltage amplifier with an open loop voltage gain
hi,
This is a Students Homework question.
E
After recently running across the modulus operation in the new PIC's Assembly manual I forgot the meaning "absolute value". It makes sense now. Gracias Eric.hola Agustin,
I 'think' the author may have been implying ' without regard to its sign',
Eric
Clip.
In mathematics, the absolute value or modulus of a real number x, denoted |x| or. , is the non-negative value of x without regard to its sign. Namely, |x| = x if x is positive, and |x| = −x if x is negative (in which case −x is positive), and |0| = 0.
