Design a Voltage Amplifier
BobTPH
Joined Jun 5, 2013
11,678
I think you are missing something in the assignment. Since it was not specified as an AC amp, and there is no frequency range specified, I think it is supposed to be a DC amp. The dual supply is also a clue.
Bob
ThyristorWolf
Joined Aug 30, 2020
10
Bob
Hi BTPH,
kindly elaborate your point of view...
MrAl
Joined Jun 17, 2014
13,889
hi Mr AI
Well it is just that op amp amplifiers are much easier to construct than transistor amplifiers. So with that in mind you should try to design one like that.
Fewer parts, fewer connections, easier to set gain and input and output impedance.
ericgibbs
Joined Jan 29, 2010
21,644
I have to design a voltage amplifier..The first task is to develop a voltage amplifier with an open loop voltage gain
hi,
This is a Students Homework question.
E
ericgibbs
Joined Jan 29, 2010
21,644
hi Bob,
It is to remind posters who are suggesting 'alternative' solutions, ie: OPA etc, that the TS bound by the specification set by his Tutor.
E
MrAl
Joined Jun 17, 2014
13,889
Hello there,
Here is what i read in the first post:
"You are free to choose any analog electronic component available
in the market to develop your amplifier. Your circuit must be designed to operate within the ±10 V "
As to my suggestion, he seemed a little lost so i though i would suggest something a little simpler, then move to the more complex.
However, whichever it is to be, i assume without doubt that the OP must design it not us. We dont do the work for them as usual in this section.
ericgibbs
Joined Jan 29, 2010
21,644
hola Agustin,
I 'think' the author may have been implying ' without regard to its sign',
Eric
Clip.
In mathematics, the absolute value or modulus of a real number x, denoted |x| or. , is the non-negative value of x without regard to its sign. Namely, |x| = x if x is positive, and |x| = −x if x is negative (in which case −x is positive), and |0| = 0.
atferrari
Joined Jan 6, 2004
5,032
hola Agustin,
Eric
Clip.
After recently running across the modulus operation in the new PIC's Assembly manual I forgot the meaning "absolute value". It makes sense now. Gracias Eric.
