inverting a negative voltage with an amplifier
jsnx
Joined Mar 17, 2022
21
I'm having trouble thinking of a way to convert a negative voltage to a positive one with an inverting OPA. I have an input voltage range of [-5 to -1]V and I need to convert it into a positive voltage to compare it with a reference voltage ( regulation for my charge pump) and I only have a positive supply voltage of 5V.
I studied the one stage OTA shown below and the minimum input voltage is \[ V_{icmin} = V_{gs1} + \frac{V_{g5}-V_{th5}}{n_{5}} \] So I can't have a negative input in my OTA.
I was wondering if there is a way to be able to use the OTA for a negative input voltage or if there is another way to convert it into a positive voltage where I won't be needing a regulation.
Thank you
38,952
A rail-rail type op amp will do that for you.
You just configure it as an inverter with two resistors.
What gain do you want?
jsnx
Joined Mar 17, 2022
21
I want a gain of one. But what is the transistor level circuit of a rail-rail op amp? is it different from a classic one stage OTA?
38,952
Yes, it's different.
You can look at the schematic in the spec sheet of a rail-rail op amp to see how they do it.
Are you trying to build you own op amp?
jsnx
Joined Mar 17, 2022
21
I'm doing a design of a circuit where I'll be needing to invert a negative voltage and everything has to be in one chip.
