i am not that much expert in handling scopes sir. Meanwhile, i want to meticulously check the 2N2222 and S850 on the pin level voltages and replace ic4093 with new one, ( may be some issue??) and then ... see if i progress.The oscilloscope is your best tool to troubleshoot this project.
Use the scope to the see what waveforms are present at those same locations.
I still suspect a noise issue possibly from the IR receiver .
sure sir, i , it is actually 9 pins ( 3 trios )to be grounded as per advice,4,5,6 & 8,9,10 then,11,12,13Before replacing the 4093 I see an issue with the pcb.
All unused input pins on the 4093 should be grounded.
Connect pins 5,6,8,9,12 and 13 to Ground, it's important.
ok, sir, sure i will not, thanks for that input. sometime i remember on an another blog, they advicing to short all unused pins. so, sorry for that.Do not ground pins 4, 10 and 11 those are outputs.
That will damage the chip.
I think that says more about the level of the designer on u tube your following .sure sir, i , it is actually 9 pins ( 3 trios )to be grounded as per advice,4,5,6 & 8,9,10 then,11,12,13
Note: it is crazy for me, the You tube who made this design not using pin 2 of IC4017, USED 4,7, 10 FOR SWITCHES IN Transmitter, where as i see the same connected to pin 2 in receiver. so, confusing for my understanding. hope you have some answer. Surprisingly, my head is still not able to figure out the theory and concept behind this one. But, i am happy, i saw it, getting a good nurturing from you, despite me a novice. i hope i will win sure. i love to complete successfully.
Here's why that is.Note: it is crazy for me, the You tube who made this design not using pin 2 of IC4017, USED 4,7, 10 FOR SWITCHES IN Transmitter, where as i see the same connected to pin 2 in receiver. so, confusing for my understanding. hope you have some answer
sorry for my delayed response. You are right on the dot. The inputs and obssessed interest to support and nurture by sghioto had been stupendous( my english not great though) and tonnes of thanks to the entire supporting hearts and to sghioto in particular. Relentlessly the replies are meticulously fast and a great hand walk. The fear in me that i am alone is fading out in this specific project. Thanks to the SMEs conducting and supporting people like me.I think that says more about the level of the designer on u tube your following .
This circuit is as others have discussed very marginal , and a terrible circuit .
It's a credit to @sghioto etc all that you are this far.
Don't blindly believe everything you read on the internet. Having an in-depth understanding of each situation will allow you to make decisions for yourself and avoid making mistakes.ok, sir, sure i will not, thanks for that input. sometime i remember on an another blog, they advicing to short all unused pins. so, sorry for that.
sir, you right. to avoid buidling new PCBs or tinker out the design that we review, and time, i use the already built boards to ensure i am able to demonstrate it. yes it is sometimes frustratig. But it saves time and multiple reworks for me. As i said earlier, i am not a good breadboard assembler. so, make some PCBs to get the right cirucit proved. having said, that i had used pin 4, 7, 10 as output points sir. not considered pin 2 at all.First question, why are there 4 circuit boards?
When button 1 on the transmitter is pressed the output should be seen on pin2 of the 4017 in the receiver.
sir, thanks. May i share what is my understood mindset with you on this aspect please.The outputs are:
pin2 for button 1
pin4 for button 2
pin7 for button 3
No sir, i wish to correct myself and assumed things, my understanding could be wrong as well. pl. excuse.Does this mean you understand the circuit design better?
Is the circuit working correctly now?
Sir, i tested and reconnected the mistakenly used pin 10 for pin 2 and checked. seems now I see a light at the end of tunnel. I am yet to connect LEDs separately, but measured the wires that i will connect to LEDs later. for HIGH Voltages. yes they work. But when i press one switch, and measured voltages on all the pins separately and put in the matrix. nothing is 0.0 volts but goes up to 1.1volts also. thank you. i will connect ith the LED and do it as well. Thank you very much.What exactly do you need to know at this juncture?
Do you have LEDs connected to output pins 2,4 and 7 on the 4017 receiver for circuit verification?
All output pins should be close to zero volts when not High.nothing is 0.0 volts but goes up to 1.1volts also.
