I found the attached circuits somewhere once. I get how it works, but suppose you hold the button longer than you should then the capacitor voltage will tend to mid-rail where it will be more sensitive to bouncing once you let go or may end up switching the inverter with input 3 if you hold it indefinitely.
When I make R1 equal to 10k the circuit appears to be better behaved in a sim. If you make R1 too small the current spikes through R1 might get bigger than you'd like(?) so don't make it too small but other than that is there a reason for R1 to be as large a value as R2?
Thanks
Thanks
