DC Voltage sensing using lv-25P
Navaneeth1285
Joined Mar 19, 2015
8
hi,
i tried to sense 80 V dc using lv-25p, i initially tried for voltage value of 10V.but i am not obtaining voltage on the secondary side,
primary side resistance is 10k ohm 10W, and my secondary side resistance in 150 ohm, i designed them to obtain a voltage of 3V on the secondary side.
i tried varying the input but there is no change in the secondary side, also my dso is showing negative value..??
Alec_t
Joined Sep 17, 2013
15,121
Wired as shown, the primary current should be 8mA if the sensed voltage is 80V. So far so good.
If I understand the datasheet correctly, the secondary current should therefore be 8*1000/2500 = 3.2mA, resulting in 0.48V across the 150 Ohms. How did you get the 3V figure? If you get 0V, either there's a wiring error or the IC is dead/fake.
Edit: Looking at the datasheet again, although the conversion ratio is stated to be 2500:1000, the nominal primary and secondary currents are 10mA and 25mA respectively, implying a conversion ratio of 1000:2500. Something is inconsistent :confused:. But that ratio should give 20mA secondary current and hence 3V across the 150 Ohms, as you said.
