6Ah. Actually a good bit less, because the Ah rating is the optimistic figure supplied by the manufacturer for the battery discharging under very specific conditions. Or are you asking about how much current (Amps, not Ampere-hours) will be drawn by a 12V-to-5V converter?how much Ah
Typically most phone chargers for automotive use take the 12 to 14 volts from the automotive system and run it through a simple voltage regulator like a LM7805 and provide 5 volts to the phone. The phone handles the rate of charge for its internal battery. The current draw is generally very little depending on the charger, typically a few hundred mA.I have a 12v 6AH battery, connected the terminals to my car charger to obtain nominal charging voltage for my phone..i
