Actually appx 11.11K for a gain of 10. You have to add 1 to the division of the two resistance values.No I mean 10x max, I’d change the 2.2k to 10k, right?
They do not suggest the capacitor. Instead they are showing that the circuit works and does not oscillate with the capacitor which might be a coaxial cable.The TI data sheet suggests a 100 pf in parallel with RL instead of in series. Im
Not sure what to do with that
hey this divided by 5 stuff. How does that math work? Is that an approximation?For the response to be flat (not -3dB) at 80Hz then you calculate a cutoff frequency of (80/5=)16 Hz.
What is the input resistance of the mic input on your amplifier?
Very thorough explanation. I appreciate the time you took. I'm still trying to understand some of the concepts and terminology. I'm a mechanical engineer so I understand the basics, but not a lot of the practical stuff.The terminology needs to be worked-out first...
| Thread starter | Similar threads | Forum | Replies | Date |
| C | Choosing the Right Power Supply for a Long LED Strip | General Electronics Chat | 11 | |
| C | Choosing a power supply for a long LED strip | Power Electronics | 10 | |
| K | Power Supply for Guitar pedals | Power Electronics | 17 | |
| D | DC motor controller/power supply | Power Electronics | 17 | |
Alternative power supply | Power Electronics | 2 |
