DC MOTOR VOLTAGE
beatsal
Joined Jan 21, 2018
425
I have a motor which has no V, I marking. I think it is either 12VDC or 24 VDC. It is @ 2" dia, 3" long and has the markings:
MY6812B,
B07053.
Trying to see if it is 12 or 24 VDC but not sure how to determine.
Sensacell
Joined Jun 19, 2012
3,785
Post a photo.
It depends on the size of the motor of course, but the windings are usually designed to attain a safe no-load RPM with a certain applied terminal voltage.
The motor will self-destruct when run at too high RPM.
Try a variable DC supply, increase the voltage slowly, stop when you reach 6000 RPM, which should be safe for a small DC brushed motor.
