DC Motor Driver with Limit Circuit Not Working
28,523
What does the L9100 driver do when both direction inputs go high at the same time??Now that I can see a circuit schematic it is clear that is what is happening now.
sarahMCML
Joined May 11, 2019
707
When both inputs are either high or low the chip goes into "Apply the Brakes" mode, as they term it, so I expect either both upper, OR both lower transistors/MOSFET's are turned on.
28,523
That appears to be what is happening when neither sensor is activared, based on the circuit in post #19. If neither transistor is conducting because neither sensor is activated, then both outputs are high.
sarahMCML
Joined May 11, 2019
707
Yes, but if the circuit is re-arranged as in my post #19, when a button is held closed, Q5 (or Q6) pulls an input low, so pulling low one or other of the driver outputs and allowing the motor to turn.
John A Bonilla
Joined Mar 11, 2017
92
Ok, here's what I mean. I've drawn all the voltages as if connected to the same 5V supply, but if you wish to run the diode from a lower voltage, don't forget the resistor! Just make sure that it's a suitable value.
EDIT: Image corrected!
Thank you for this!
Although I am somewhat confused by this design. To my understanding the 5V running through the 1k Ohm resistor would result in almost no voltage flowing to the IA or IB pins. Also when the button is pushed down and the opto npn transistor is not active, the Q1 npn opens therefore setting the IB voltage to 0V when it shouldn't resulting in the motor not spinning. Please let me know if I am understanding this wrong.
28,523
Do we actually know the input versus output current/voltage relationships for this driver device?? Certainly that may have a great effect on the response. I have not looked up the data sheets on the L9100 driver, but the requirements should have been examined and verified as part of the design process.
sarahMCML
Joined May 11, 2019
707
Thank you for this!
With my circuit attached, and the inputs IA & IB connected to the collectors of the transistors Q5 & Q6, and no buttons pressed, the voltage on both inputs should be pulled High by the 1k resistors to approximately+5v, and the motor should be stopped.
If either buttons is pressed, the corresponding input, either IA or IB should be pulled Low to nearly 0V, and the motor should rotate!
John A Bonilla
Joined Mar 11, 2017
92
Ok thanks! I understand now, I appreciate the help!
