DC Boost Conventer Voltage drop.
ExpL0siV3Man79
Joined Jun 4, 2018
93
I made a dc boost converter that takes in 5 V DC and gives out from 8 to 30 V DC depending on the duty cycle . But as soon as I attach a load like an LED the volage drops to 4.3 volts instantly . What can cause such a problem I know that an LED can draw much current but I added an 1kOhm resistor to reduce the drop . Spoiler alert it didnt work , I still get 4.3 V even when I put it on the 30V mode . Any ideas ?
Schematic included at this link : http://tinyurl.com/y9jnnc29
PS : the simulation is not displaying the actual voltage values but every other value is as used in my circuit (inductor capacitor frequency) . The link is just here for the schematic diagram
MOD: Added the clip from the link.E
ExpL0siV3Man79
Joined Jun 4, 2018
93
It is 1mF not 1uF check my schematic please . Can you try it with this value ? Also Can you attach an LED between the resistor and ground ?
ExpL0siV3Man79
Joined Jun 4, 2018
93
Yes it is never mind I fixed it now 10Khz gives 15V DC and 100kHz gives 60V DC , By the way my multimeter also measures 90V ac . Is this even posible?
28,595
The simulator circuit has no feedback and thus it has no way of responding to the increased load. Use a real world circuit with feedback and it will work correctly.
