So if you were to design something like that, is it customary to place a filter cap where you did? How do you know what values? Can you calculate that?
Thanks!
Yes it is customary to put a small filter capacitor between collector to base to quench oscilations in the stage, it's called negative feedback, there are numerous ways to do it professionaly, For me, I experimentally at random placed those value capacitors in there, until it worked.
I'll show you the steps to design a basic transistor amplifier at 2 levels.
Beginners basic. and advanced basic. These are only BASIC ways to do it.
I am only a hobbyist at this no professional experiance, so take this at a hobby level.
BEGINNERS BASIC:
Assuming a NPN transistor silicon Vbe = 0.7v. NO LOAD!
step 1. choose a value for VCC (supply voltage)
step 2. choose a value for RC (collector bias resistor)
formulas to know at this point VC = VCC/2 and IC = VC/RC and AV = RC/RE
step 3. Solve for IC
step 4. Choose voltage gain (AV) and solve for RE RE= RC/AV
formula to know at this point VE= IC X RE and VB = (VE + Vbe)
step 5. Solve for VE and VB
step 6. choose the base bias resistor to use from base to ground call it R2.
Rule of thumb R2 > 5 to 20 times RE.
formula to know at this point IB2 = VB/R2 and R1 = (VCC-VB)/IB2
step 7. solve for R1 (the remaining base bias resistor from base to positive supply)
step 8. Breadboard the circuit and check voltages against your calculations,
If VC is lower than your calculations by a significant amount than the
transistor is running to hard at quiescence, then either lower R2 or raise R1 higher.
if VC is too high than transistor is not running hard enough so lower R1 or raise R2.
You will not get exact voltages as calculated due to component tolerances, but adjust values to get them as close as possible.
ADVANCED BASIC:
Assuming a NPN transistor.
step 1. Look at all parameters the amp must work at. Impedances load, input, output, etc...
input signal, output signal gain, frequencies, the list goes on..
step 2. Determine the VCC needed to give the output voltage swing required for amplification.
step 3. Make RC much lower in value compared to the load it's driving. But make sure it is high
enough to be able to get the required AV.(RC/RE) juggle values to get best choice.
step 4. with RC and RE chosen for AV. calculate the IC that will result with these choices.
step 5. Choose R2 to be higher with respect to the signal voltage output impedance feeding it.
Again juggle values so as to keep it within range to bias the transistor.
step 6. calculate the value of R1 needed to bias the transistor.
step 7. Breadboard the circuit and check for proper voltages in key areas VC ect..
adjust values keeping in mind the constraints of input and output impedances, ect...
step 8. Do a dynamic test to check for signal amplification, ect...
step 9. It just goes on and on and on, until you get a satisfactory design you calculate than
build and test, over and over until you get it working.
So this is just to give you a little background in Basic transistor circuit design, there are
alot of parameters that have to be worked with to get a circuit to work properly, thats why it's good to PRACTICE designing basic circuits over and over until you get a good sense of why
the circuit is behaving the way it is.
I have found out that when a circuit dosen't work right the 1st. 2nd. 3rd......n..times is when I learn the most on how to design that circuit, because
now I have been through all it's failures to know how to make it not fail, by extensive research on that particular circuit.
Keep up the good work, with your desire to learn this stuff.
