Hi All
I need a little advice about setting up a circuit for the following current sensor.
http://www.farnell.com/datasheets/51649.pdf
I wish to use it to measure the current running through a bus bar which will have a current between 0 to a maximum of 450A running through it, my concern is how to interface this with a microcontroller that can take a maximum of 3v3. Do I need to have an external voltage at Vref? Can I just input the output of this sensor straight to the controller via for example filters (i.e. butterworth filters) just to remove high frequency componenets.
Art
Art
