Current-Sensing Mosfet
cmartinez
Joined Jan 17, 2007
8,763
I've been working on a project that may or may not require current monitoring at a Fet's output, and so far the only technique that I've been learning is the one that uses a sense resistor and an op-amp to get an output voltage that is proportional the the current through the resistor.
But after doing some browsing around, I found this very strange component, which is a Current-Sensing N-Fet. I did some googling, and this is what I found about this technology.
Does anyone here know how they work and how to use them? Or perhaps point me to a proper application note that I could study?
ronv
Joined Nov 12, 2008
3,770
Another possibility.
http://www.allegromicro.com/en/Products/Current-Sensor-ICs.aspx
jpanhalt
Joined Jan 18, 2008
11,087
You can also just sense Vds(on) across an ordinary mosfet. I saw a circuit for doing that several years ago. If that approach interests you, I will try to look it up. Don't know how it compares in accuracy to the other methods. A brief search didn't find it, but here are some similar approaches:
http://www.cel.com/pdf/appnotes/an3024.pdf
Device with Vds built in:
http://www.infineon.com/dgdl/Infine...N.pdf?fileId=5546d462533600a4015355a82da21342
Controller with circuit built in:
http://www.ti.com/lit/ds/snos738h/snos738h.pdf
John
cmartinez
Joined Jan 17, 2007
8,763
John
Wow, John. Those are extremely interesting documents... thanks!
cmartinez
Joined Jan 17, 2007
8,763
The LM9061/-Q1 High-Side Protection Controller seems promising, since it has inherent over current protection.
