DickCappels
- Joined Aug 21, 2008
- 10,661
Thanks... But I think this i not related to limitations and temperature...View attachment 121848
If the output is in current limit, as the die heats up because of the power dissipated the output current drops.
I'm sorry I didn't answered to all the questions.When you say "I had an input current that was coming from a sensor", I still don't think you 'get' it. It would be possible that the sensor drives, let's say, 1mA, in which case, if your op amp has an input resistance of 1k, your sensor would produce a voltage of 1V, or if you connected it to a different amp with an input resistance of 2k, then the sensor would put 2V on its input - but I honestly don't think that's likely. Much more probable is that it produces a known voltage, rather than a known current. What kind of sensor are you using? Can you say something about it? The current going into the op amp is much more likely to dependend on the op-amp itself - very unlikely that it is dependent on the sensor.
Also, what current do you need after amplification? You say to drive a motor or LED. If you were going to directly drive a motor from an op-amp, it would have to be an unusually tiny motor.
You didn't answer the question about the nature of the work you're doing - experimental lab work, or application circuit.
Yes, you should have IL = 34 mA. What is the resistance of your load resistor? The resistance of load resistor RL should be very much less than 100 k Ohm. Don't forget also that output voltage can't be greater than supply voltage,Ok, thanks to all that replied to me!
I'm using an LM358N. All the resistors but R3 are 100kΩ. +Vcc = 12.16V. I also have a -Vcc = 12.16V if needed.
So, I'm going to try using +Vcc and -Vcc to feed the OpAmp and a 100Ω for R3 to see if anything changes! I would get 34mA at RL, right?
If needed, I could also use a diode (1N4007) at the input to limit the input voltage to 0.67V or so!
Edited;
With the rail-to-rail voltage supply and a 100Ω R3, I'm measuring around 27mA. But for some reason this value is decaying over time. I'm uploading a video about this. Is there any reason for current value dropping over time?
I would think that the circuit in Post #25 of this thread does need a split supply. Not ever having done a circuit with LM358, I'm not certain that it is suitable for this application. From a Data book, LM358 is configured to work from a single supply. or a split supply. I can't say exactly what happens when it is in a circuit with a split supply.I may be missing something but this circuit appears to need a negative power supply. Is that true PeterHL?
This is stating the voltage divider rule incorrectly. The voltage divider rule IS given correctly in the tutorial that you link to in your post #42.I'm sure you know that if you apply a voltage to two resistors in series, (V ------R1-------R2------gnd) then the voltage between the two resistors is (R2/R1 x V).
Oops! Apologies. Before declutching fingers, engage brain!This is stating the voltage divider rule incorrectly.
If E2 = the voltage drop across resistor R2 with respect to ground, then
E2 = R2*V/ (R1 + R2)
I'm using exactly the circuit of your post #25 and my RL is just the LED. I'm not sure what you mean in the underlined text of your message but I think you mean a GND node. Yes, the power supply I'm using has 5 outputs:Yes, you should have IL = 34 mA. What is the resistance of your load resistor? The resistance of load resistor RL should be very much less than 100 k Ohm. Don't forget also that output voltage can't be greater than supply voltage,
Eout = RL * IL
Do you have a common termination from your split power supply? Have you made the common termination ground for the circuit?
According to a current limiting graph that I have for LM358, at room temperature current is limited to a maximum of about 40 mA.
If you could post the schematic diagram of the circuit that you built that would probably be helpful. Maybe also try testing with R3 = 1 k Ohm.
-Pete
If I don't use the split power supply, I think the circuit doesn't work.I would think that the circuit in Post #25 of this thread does need a split supply. Not ever having done a circuit with LM358, I'm not certain that it is suitable for this application. From a Data book, LM358 is configured to work from a single supply. or a split supply. I can't say exactly what happens when it is in a circuit with a split supply.
In the LTSpice circuit I used the 1N4148 just because there was no green Led in the database (i guess). But in the real circuit, I'm using a green Led.Is the load in the circuit that you are testing 1N4148 (a signal diode) or a LED?
Yes, your math is correct. Analyzing how this circuit works I think is not too easy. Offhand, I can't explain, but with some effort might be able to. There are (engineers) at AAC that understand how it operates. Nevertheless, this is a fairly ingenious and unique type of current source.
