- Joined Jan 23, 2018
- 28,212
Hi All,
This is first post.
Due to dust or so, the said Volume Control Wheel does not work properly. Sample pic:
I often clean controls with denatured alcohol and that usually works well. Much less expensive than contact cleaner.
Volume goes to one speaker, and other gets muted. Vice versa. When I carefully turn the wheel sometimes the Volume works properly or sometimes with noise or muted one side.
As I write this, I've cleaned it up with Petrol drops. PCB is drying. I chose Petrol because Contact Cleaner is expensive solution. Am I correct or any other method could be used?
UPDATE: I tried with Petrol but it doesn't work. Some search results said it worked for some but not in my case. Volume comes in the right speaker and Sub-woofer now. When I turn the wheel cracking sound still coming.
I shall try for the Contact Cleaner else I'll buy one. but it's expensive in my country (a good one for $30+). Do you have any idea whether I could get this spare in the market? Search results say Creative doesn't make them? Very strange
THINKING: Does dumping Volume control diminishes any Sound Output or Quality? I opened the VCU but I'm not comfortable how join those leads
Thank you.
