thanks for your replyHave you tried cycling the power off?
sorry i am not that professional in this field , what do you mean ?Can you tell if the amp is doing anything at all?
it doesn't make any sound or lightYou don't need to be a professional to see if it is making any sound or see if any lights are coming on.
yes sureHello,
I see an open 12 Volts DC connection.
Is the 12 Volts DC connected?
i just checked it and it's working fine and delivering the right voltage , everything working fine and the sound is clear as always , but the problem with the bass controller , it doesn't change the bass level , the bass is ON but at fixed level i can't control it anymore , but everything else is fine.Thank you. No output at all sends us to simple things first. Check the power supply to see if it is delivering the right voltage. If that's good, we move to checking the on/off switch and looking for fuses.
it's the 3.5 jack that's connected from the sub to the PCHello,
What does the yellow/green thing do, with the text audio input above it?
OK, that rules out a lot of obvious stuff but unfortunately makes things more complicated....the bass is ON but at fixed level i can't control it anymore , but everything else is fine.
