Your logic seems sound. Keep in mind, if you measure less than the manufacturer says, he is quoting worst case, and that is what you need to plan for.
But your math is sound.
You laptops will have specifications, those are a safer number to use.
Q2 using a 2N3055 will still burn up (be hot), but it is designed for a heat sink. You need to add one.
