Is there is a scientific reason or just Nope?Nope.
Two separate primaries with a single common secondary? I cannot figure out how to build that Dick. ¿¿??I know a guy who did this with two phases in flyback mode but he used two cores to do it. The result was almost DC at the output.
They were two chokes on separate cores being driven as non-isolated flyback converters with their outputs ORed with rectifiers. There were no secondaries. What I intended to convey with "The result was almost DC at the output" was the idea of the ripple acros the not-mentioned capacitor was very low. Clever, it was.Two separate primaries with a single common secondary? I cannot figure out how to build that Dick. ¿¿??
Could you elaborate?
Actually, I want to make an electrostatic coil (nearly), to simplify STANLEY MEYER VIC circuit. he used electrostatic charges to split water molecules. I thought that this configuration might work as an electrostatic generator. anyway, thank you.Try a Core like this one ...........
Look up a video on a Hiemz Transformer.
You can accomplish what you are trying by using 3 Cores, and 3-Bridge Rectifiers, it's called 3-Phase AC Power.
only 5 to 10% Ripple under Load.
You can't get DC out of a Transformer ........
Maybe you were trying to get rid of the Rectifier Losses ????
Rectifier Losses can be almost eliminated,
but it's going to cost more to use FETs, and a Current Sensor, and a few more odd parts,
to make an extremely Low Loss Bridge Rectifier.
For high power, there's almost no getting away from a Huge Inductor and ~20 Capacitors, followed by a Buck Regulator.
Nobody uses the configuration you are attempting to use, you should take the hint and save some time.
.View attachment 227663
Yet another one of these threads that are so close to being over unity, that they should be called over unity light. Why on a forum that is considered *scientific*, are things like this even allowed? Meyer was a scammer nothing more than that, definitely no scientist.Actually, I want to make an electrostatic coil (nearly), to simplify STANLEY MEYER VIC circuit.
That's why I say, "free energy light". Most people that are going for it think it can be used to run a vehicle, that is the myth Meyer was spreading, run a car on HHO. But they never understand how little the amount of gas is made by the process or how much it would take to run even a small ICE. The Meyer myth is a big time thing on some over unity type sites.HHO is not like free energy, it is more like a method to store or convert energy to another form.
And built a prototype to demonstrate the lofty claims? Documented and peer reviewed publication?I've designed an Engine...
You mean the ridicule you just posted? I'm shaking in my boots, oh wait, I'm not wearing any.Just because YOU don't understand it, and are terribly afraid of ridicule, doesn't mean that it doesn't work.
