bought a remote control light sw device, but want it to act as a 2-way sw using existing normal wall light sw and with no relays on when the light is off. The relevant bit of the remote device:
12v through relay (ie this supply switches the relay, the other side of the relay is mains AC) grounds via s8050 npn transistor (this does the remote switching). Specifically:
collector to relay
base to switching device
emittor to -ve
using presumably more transistor(s) i want to make this work as a 2-way sw using the existing wall sw as the other sw. I have had a good crack after googling about transistor 2-way switches, but no result. I can't get my head round how to do it, maybe because it is the ground being switched not the +ve?
+5v is also available on the board.
help appreciated.
James
collector to relay
emittor to -ve
help appreciated.
James
