- Joined Jan 23, 2018
- 28,488
Unsoldering one end is still a valid option.
Not on that style of meter. That is part of the reason for the two large terminal posts, because often they support the meter "movement." Not always, but often.Military meters have to withstand a lot more vibration.Doesn’t the back come off?
How do you calculate that?1/4 W will be fine.
Did you see my calculation in #35? Is .7W not much?the 19.9 volts will be dropped across the series resistor. So the power will not be very much
If the meter is only reading 12V (when running) the car has a serious problem. Try 14V. A 1/4 W resistor is too low. I would use 1W.I do see that and consider that at 12 volts the current will be less. At 20 volts the resistor is overheating, but since in an automotive system 20 volts means a serious problem, protecting the meter by failing open is the best plan.
@12V, P=12x12/560=144/560=0.2571W, which is about 1/4 watt.
