Convert 9V to 5V
Quillion
Joined Jul 18, 2009
10
Hello I am quiet nooby at the whole art of circuitry. All I had was a little robot to practise on, so he used a 9V battery and converted it to 5V. Now all of my equipment uses 5V and I recently brought 78M05 voltage regulator, so I have quiet a few parts so its not a problem, but can someone please show me how to build a circuit where I connect a 9V battery to the breadboard and by using my voltage regulator I change it to 5V
Please help me
Thank you very much
ELECTRONERD
Joined May 26, 2009
1,147
Please help me
Thank you very much
You can simply use a voltage divider shown below:
Now, you want a 5V output so we'll have that for Vout and Vin is 9V. We'll just pick a random resistor value for R2 because of the ratio (but we'll have it in the KΩ range)...so for R1 you'll need a 19KΩ and for R2 you'll need a 20KΩ resistor. This will give you 4.6V which is very close.
ELECTRONERD
Joined May 26, 2009
1,147
Thanks guys, after I put the post I thought that a voltage divider couldn't supply much current...especially if they are "resistors."
I am learning day by day through trial and error and through everyone here. Thanks for making AAC such a success! I absolutely love learning about electronics and I hope that you will continue to support each person including me. I'm not the wizard here so may the more experienced tell me about the advantages and disadvantages of the things I suggest (like this voltage divider). Thanks again!
Quillion
Joined Jul 18, 2009
10
See the attached picture and connect your 9 volts battery positive to input and negative to ground.
You will read 5 Volts measuring from groung and the output pin.
Alberto
You must also use a capacitor on the output terminal to ground. 0.1uF to 10uF is good.
There is usually a circuit in the datasheet. For the 78M05, check here (page 7):
http://www.national.com/ds/LM/LM341.pdf#page=1
John
THANK YOU VERY VERY MUCH it works awesomely and now I didn't even fry my microcontroller
Audioguru
Joined Dec 20, 2007
11,248
A 9V alkaline battery quickly drops to 7.2V. But the 78M05 regulator performs poorly when its input is less than 8V and the datasheet does not have a minimum input voltage.
Therefore you should use a "low dropout" 5V regulator that works fine until its input drops below 5.5V or less.
Wendy
Joined Mar 24, 2008
23,415
I like zeners myself. Another approach for a low insertion loss regulator would look something like this.
I got this from my LEDs, 555s, Flashers, and Light Chasers article. You would need to modify it (obviously), but the principle remains. You didn't say how much current you needed, so I can only speculate what the resistor would need to be, but the zener would need to be a 5.6V unit.
Wendy
Joined Mar 24, 2008
23,415
True enough.
Voltage regulators do draw continuous current, and as audioguru pointed out, there are limits to what a 7805 can do with a low voltage.
vectravanman
Joined Mar 2, 2012
12
Rather than create a new thread, i thought i would add to this thread as my problem regarding a similar issue. My task is to create a PCB to output data to an LCD display using a 9V battery and PIC. I am also new to designing schematics and working in the electronics field so any feedback would be helpful. If i use an LM78M05CDT regulator to convert 9V to 5V will i then be able to use a voltage divider circuit to convert 5V to 4V as i need 4V for my LCD but 5V most other devices in my circuit.
Thanks
Audioguru
Joined Dec 20, 2007
11,248
Vectra Van Man,
Please read earlier in this thread:
1) An old 78M05 does not work when a 9V battery is not brand new. Use a low dropout regulator instead.
2) A voltage divider does not work when it has a load. Use a series silicon diode to reduce 5V to 4.3V.
vectravanman
Joined Mar 2, 2012
12
Thanks for the reply Audioguru
I have tried designing a circuit with two voltage regulators one with an adjustable output to give 4V. The circuit looks something like this.
Is this a suitable circuit layout or do i need to add more to get the voltage im looking for?
Audioguru
Joined Dec 20, 2007
11,248
Vectra Van Man,
The LT1763 regulator is very small and has many pins.
I guess you did not read the datasheet for the LT1763 series regulators:
1) An LT1763 is the adjustable one. An LT1763-5 is the 5V one.
You show an adjustable one with an unregulated output (its ADJ pin is not connected) and a second adjustable one with a 1.76V output because your arithmatic is wrong.
2) Their MINIMUM output capacitor is 3.3uF but the datasheet shows that a 4.7uF cap is better and a 10uF cap is best.
3) The datasheet says with a battery input then use a 1uF to 10uF input capacitor.
You show the polarity of the battery backwards.
vectravanman
Joined Mar 2, 2012
12
Thanks audioguru
Have actually decided to just use the 5V regulator and produce 4V through a resistor going to 2 series LED dies which are used on my LCD. This is the only part of my circuit that requires 4V. Its a pain but i think this will work.
I am pretty new to Electronics Design so i appreciate this feedback as a lot of it is still over my head.
