Convert 120Watts to 15000Watts
Jacquesl
Joined Dec 9, 2006
29
Combine 1V @ 60A = 60Watts
250V @ 0.24A = 60Watts
So my big question is, can I take that two separately 60watt power supply = 120watt
And make it give me a output of total 250V @ 60A = 15000Watts :rolleyes:
Combine the to inputs and feed it to a transformer
In theory, I will end up with 120Watts and not 15000Watts
and how does it work, that I can send a DC source of 28V @ 10A and 250V @ 0.30A down the same cable but that 10A doesn’t help then it come to the 250V
So that 10A it’s only available then it comes to the 28V loads and the same with the 250V @ 0.30A
So does anyone know a solution?
kubeek
Joined Sep 20, 2005
5,796
I totaly don´t know what you are talking about.
So you want to combine the power supllies in series, right? Then the voltage (are we talking about DC or AC?) adds up and the current is limited by the lower of what the two supllies are capable of. So you can get alltogether 251V@0.24A = 60.24W.
Simply you can´t have 28V and 250V in one cable at the same time, unless you have multiple wires in it (at least three).
22,105
Listen very carefully. There is no free lunch, and there never was, and there never will be!
hgmjr
Joined Jan 28, 2005
9,027
I am afraid what you are proposing is not possible.
The output of two separate power supplies do not combine in the manner you have described.
You may want to visit the tutorial at www.AllAboutCircuits.com and read up in DC circuits. This will provide you with a better understanding of the behaviour of DC power sources when combined in series.
hgmjr
Jacquesl
Joined Dec 9, 2006
29
Sorry for taking so long…. to respond, I wasn’t notified by email :confused: email I probably did not ticked the notification ticker
Yip I know this will be impossible to do just by using the ordinary electronic parts, but this “Convert 120Watts to 15000Watts” is only a example :eek:
What about his Idea, a small nuclear reaction inside the PSU, this stuff doesn’t exist yet, and use the hydrogen to feed a fuel cell, if It have to, you will probably not want an internal combustion chamber inside your UPS or TV. lol
Take the CO2 make the C turn into H via neutron capture and then you just use that O2 + H = Energy
If you turn C to H there will be some energy release I’m not yet 100% sure where, but somewhere there will be a gain, because it took energy to make H-1 turn to C
So I want to take C-12 / C-13 and convert the isotopes to C-1, but now someone told me, I cant make it C-1, I can only make it C-8, so that sucks, I still belief, there might be some possible, so in the end we will have a problem with not enough CO2 pollution and a water rise from all the units, lol
The heavier a element gets the more energy is absorb inside it, like U and Po, and very packed with energy and it’s way down on the Isotope and Periodic table
Jacquesl
Joined Dec 9, 2006
29
No for real, I connected DC-28V @10Amps and DC-250V @.30Amps all in the same cable + and – “2 wires” with the use of diodes of course and then the DC-250V gets drained by the bulb then the DC-28V try’s to keep up, with a low glow,
AC will also work, if it’s well synchronized, but DC is easier
But it’s all just for testing purpose, it’s not really practical to do it like that, just for fun, I did that 4 months ago
thingmaker3
Joined May 16, 2005
5,083
Total circuit current equals Applied Voltage divided by Total Circuit Impedence. Period.
The maximum safe operating ampacity of the power supplies don't mean a whit. Ohm's Law is called a "law" because it always works, all the time, every time, no exceptions. Ever. No matter what one's mind-set may be.
As far as science fiction mumbo-jumbo, I always liked "zero point energy." Much more science ficiton mumbo-jumbo, and we'll need to move this thread into the "off topic" forum.
Jacquesl
Joined Dec 9, 2006
29
I think the rest of us can now safely ignore your ramblings since they contain no useful content.
Lol, ok suite yourself, you can stay with your 4 parts, coils, caps, resistors and transistors ;)
I still think nuclear “lowest radiation” might be our future.
Well it was a try, It will probably not work :cool:
thingmaker3, your right this is starting to go off topic, it’s not a allaboutnuclear forum :D
