Controlling a Dc motor
Setofdraws
Joined Aug 9, 2021
14
Hello, apologies if i have posted in the wrong thread or if i have asked this question again but i need some help.. I managed to dismantle a plush toy (with moving parts) which i am going to incorporate in my project. The only problem is that it has a push button so in order to activate the cycle (moving arms) you have to push the button and after a few seconds it stops. If you push the button before it stops it stops. As such, there appears to be some sort of microcontroller which stops the cycle. I'm a newbie to all this electronic stuff but is there another way to incorporate another switch where the cycle continues without the need to push the switch again?
MaxHeadRoom
Joined Jul 18, 2013
30,665
Ideally there requires a little reverse engineering, even if it is at the simple level, IOW, some idea of the control board or what devices it has on it.
An external circuit could be designed that implements P.B. simulation, but knowing basic details of the circuit inputs would help alot.
