Control 3W led intensity with li-ion cell using potentiometer
Vindhyachal Takniki
Joined Nov 3, 2014
598
1. I have to control a 3W single led intensity, need to vary intensity linearly from 0 to 100% as user rotates potentioneter of 10K.
2. is there any dedicated low cost asic solution available for this, which can do this.
3. Most of i have checked need a PWM signal to ic like here
http://www.ti.com/power-management/led-driver/led-lighting/products.html#p207=DC Linear;DC/DC&p2297=Analog
I am looking for some solution where a potentiometer can do the dimming directly, instead of connecting additional ckt for asic
4. Voltage of Li-Ion cell: 3 to 4.2V
if charging, then voltage go to 5V from main adapter
So input voltage for IC go from 3V to 4.2V
bertus
Joined Apr 5, 2008
23,042
What are the specs of the led and battery?
How are you charging the battery?
A to high voltage on a LI battery may cause fire.
Bertus
