Constant current source problem
psoke0
Joined Mar 31, 2017
205
You've got it, grasshopper. :D
Looking at all the voltages often make it clear what's happening in the circuit.
The op amps positive input voltage is slightly lower than the negative input so its output is low, and there is thus no voltage to turn Q2 on.
It would appear that your supply voltage is only 4.85V, not 5.1V as you earlier stated.
But how did you measure 4.85V, 4.83V, and 4.81V for the same supply voltage?
(Which brings up the point that all those nodes are at the same voltage so only one measurement would have been required.)
Is the source a battery that was nearly discharged?
So you should use a reference voltage source, (such as the cheap TL431) to provide the voltage for IC1a's (-) input so that any supply voltage change doesn't affect its trip point.
hahah thank you very much :D the reason i get different voltages is that my breadboard and jumper cables have too much resistance and my power supply is old desktop computer power supply which can give me 5,1 v and upto 15 Amps i think the reason that i get voltage drop on load is because also the cables that coming from my power supply i think they have high resistance :) so what i did is i remove the comparator (just for testing current draw for now :) ) i take the components from breadboard and i just soldered all like this (picture down below) and i get 450 mA charging current to the cell :))) so tomorrow i will play with it and see whats going on :) thank you very much guys i will ask you later on another questions about this curcuit . i loved this website and people that makes this website awesome :D here is the curcuit
psoke0
Joined Mar 31, 2017
205
Hi crutschow,
As there is no load on the output it explains why it is working in voltage limiting mode. I am wondering how low the "5.1 volts" will drop if it is attempting to supply 0.7 amps. (The TSs constant current figure.)
psoke0,
Can you load the output of your 5.1 volts source with a 6.8 ohm 5 watt (or larger.) resistor to simulate the load that would be taken by the charging circuit and measure it's voltage under those conditions. (This will draw just over 0.7 amps)
Les.
Les. i will do it tomorrow i think the problem is not the power supply its cables resistance
38,512
Here's an LTspice simulation of your circuit with a TL431 reference to make the trip point independent of the supply voltage.
(Note: I see no reason for C1 in your circuit.)
The circuit cuts off the charge current at a nominal battery voltage 4.1V for the resistor values shown.
You can use a 10kΩ pot in place of R4 if you want to make the cutoff point adjustable.
Note that the charging current of 700m is marginally close to the 800mA maximum current rating of Q1.
I suggest you increase the value of R1 to about 1.5Ω to keep the current below 0.5A for that transistor.
psoke0
Joined Mar 31, 2017
205
Here's your circuit with a TL431 reference to make the trip point independent of the supply voltage.
the C1 is acting like battery just for see it in smulation :) and your link is not opening i cant see the curcuit you give
EDİT : i see the curcuit now thank you :D
psoke0
Joined Mar 31, 2017
205
and what is the program you are using can you tell me please :)
38,512
Good. :)
Note my edit to post #44.
I'm using LTspice, a free download from Linear Technology.
psoke0
Joined Mar 31, 2017
205
If you want to simulate that in LTspice you will need to add the models for the LM324 op amp and the TL431 regulator, which I can post, if you need them.
i just downloaded it yes i will need them :D lm358 is the same as lm324 right because i have 358 one
38,512
Yes, they are essentially the same with the LM324 being a quad in a package, and the LM358 being a dual.
The TL431 files are attached below:
The .asy file goes in the C:\Program Files\LTC\LTspiceIV\lib\sym\References directory.
The .lib file goes in the C:\Program Files\LTC\LTspiceIV\lib\sub directory.
(If you are using a newer version of LTspice then you will need to look for the directory locations on your computer)
Be sure and make a backup of both directories before making the addition.
I also attached the sim with the capacitor.
Note that you can't use 10F for the capacitor value since that is interpreted as 10 femto farads by LTspice.
Also 10M is interpreted as 10 milli by LTspice (a common mistake when using Spice); for 10 million you need to write it as 10meg (or 10MEG).
LTspice ignores letter case.
psoke0
Joined Mar 31, 2017
205
okay i need comparator model too :D
psoke0
Joined Mar 31, 2017
205
okay i tested the curcuit but without shutt off power section. i tested the current draw i see when i plug the battery the battery draw 450 mA current but when i am not using the battery im shorting the cables the amp draw jumps to 690 mA isnt that supposed to be stay at 450 mA even in short circuit because its constant current curcuit right. what am i missing here educate me please :D
LesJones
Joined Jan 8, 2017
4,511
With your 1 ohm sense resistor the current should be about 700 mA. So the 690 mA when the output is shorted is about right. What is the MEASURED voltage input to your circuit when the output is shorted. In other words what is the voltage from your supply that you claim is 5.1 volts when it is providing 690 mA of current ?
Les.
